Battery Change problem - iPhone in Recovery mode
Hi guys,
i followed the step-by-step guide to change the battery of my iPhone 5. I did everything as said but after changing the battery my iPhone can't be switched on again (without connecting the power). I assume something with the battery or battery connection is wrong. After connecting it to a power source it says "connect to iTunes". iTunes however says that it has discovered an iPhone in recovery mode which has to be restored. After I restore it iTunes says that it has to show up on the left but it only says "iPhone detected in recovery mode" after 5 seconds after the restore. Although it has obviously a problem with restoring it doesn't say "recovery error".
I also changed the battery back to the original one but the problem still exist.
Do you have an idea what to do? I don't want to give up that easy and buys new one.
Thanks so far!
Patrick
iOS System Recovery and iOS System Recovery for Mac allows you to fix iPhone stuck in recovery loop/recovery mode/white Apple logo screen/black screen and so on with a click, ever after updating to the latest iOS 10/9.3.3.
由 youzera 完成的
