Display not working after replacement
I just replaced the display. I plugged it in and it worked. Removed it, installed the digitizer and replugged the display and now the display won't come on
Try a reset. Hold down the power button and the home button simultaneously until you see the apple logo. If this doesn't work, you likely blew a fuse. You can google the fuse locations and replace it or bridge it with a bit of solder. Good luck!
这个答案有帮助吗?
Hi,
Wait until the battery is discharged. This can happen if you remove the display before power off the device.
Regards.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 168
