Can't partition new 500GB drive?
Installed 500GB drive. MacBook recognizes drive but Disk Utility shows 3.6TB! When I try to partition the drive it fails with input/output error. Have rebooted several times from OS X install disc.
Sorry dolmen ;-{
Your system can only handle SATA I (1.5 Gb/s) drives. See if this Toshiba drive offers a jumper to drop the I/O speed (check the spec sheet for it online).
Also, make sure your firmware is unto date, checkout this Apple TN on how to check it and update it EFI & SMC firmware updates for Intel-based Macs
这个答案有帮助吗?
Double check that you have the right SATA type… a SATA I or II not a SATA iii (what many new drives are).
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 79
2条评论
Thanks Machead3, but it's a Toshiba SATA 2 (3GB/s).
由 dolmon 完成的
Thats SATA II (3.0Gb/s) b=bits B=Bytes
由 DanJ 完成的
