跳转到主内容
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
power control does not work.freezes
How to fix power control button? It freezes if it is slightly depressed. Must hold down in order to power off. Is it just a button failure? help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Try using menu (Apple->Shutdown) instead of the button. Bumping or quickly depressing the power button might cause a crash under "normal" situations.
I agree your power button could be going bad. You'd have to find one on e-bay or replace the entire top case.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for responding...it will power off but only if I hold down pwer button until it shuts down...that is when it freezes-actually as soon as I depress button it freezes. the option you suggested I will try
完成的
添加一条评论
添加你的答案
joseph 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 94
