跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
Soaked iPad Air in scented/fragrance oils
One of those stupid oil diffusers with the sticks coming out the top got tipped over and my new ipad air sat in the oil - possibly overnight we're not sure when it got knocked over.
There is oil seeping out of the back-mounted microphone which we tried to soak up with cotton...but then we noticed oil spreading across the screen.
Right now it's sitting in a bag of white rice, which probably won't work but it was the only thing we could think to do.
We bought it exactly 31 days ago so AppleCare+ isn't an option.
I'm considering opening the ipad and cleaning up the oil but wondering if it is worth the time and how I will affix the screen back onto the ipad after I've heated up the glue and taken it apart.
Any suggestion and all advice is much appreciated. Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Ouch!
The rice trick really only works on water and is still limited in its effectiveness.
Sadly, once the oil gets into the screen the iPad is likely a loss. The amount of work to clean this up will be costly. You'll need a new screen and digitizer to start with and all of the oil still inside needs to be cleaned out. There are some porous materials and components that may also need replacing (battery, speakers & microphone).
Do you have Apples' Extended AppleCare (not the standard product warranty which is also called AppleCare)? if you do you can get your system exchanged out. Otherwise you might see what your home owner or rental insurance covers.
You may be able to get some money selling it as parts. Pleasant smelling at that ;-}
Sorry ;-{
这个答案有帮助吗?
得分 3
4条评论:
I'm not familiar with Apples' Extended AppleCare. Is that something we needed to purchase in the store? My concern is that in order to purchase additional coverage they'll look at the ipad and realize it's been damaged. Exchanging the system would be ideal - do you know if there is a fee for that?
My wife is on the phone with Apple right now...I'll update as I have more info. And thank you in advance.
完成的
Sorry - Yes its something you buy at the time of purchase or a few days after wards (limited window of time).
完成的
Thanks for all your help Dan (I really like your lobster btw). We talked to Apple and there was nothing that could be done on their end despite the diagnostic coming back clean, we just barely missed that 30-day window. C'est la vie.
完成的
I love a good lobster dinner ;-} Sorry your luck ran out here. Please score & mark the answer as accepted - Thanks!
完成的
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 582
