跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 5 only charges when turned on
Hi, I have a strange one here with a customers phone. The phone came to me after someone else had changed the battery on it. The phone wouldn't come on and wouldn't charge and the other person refused to resolve the problem. I changed the battery and dock connector, charged the phone up to 100% as it had some juice in the battery anyway and gave the phone back. The phone was returned to me the following day with the customer saying it won't come back on. I tried it with my charger and had no luck, I then removed the battery and tried it in another phone and it charged fine. I returned the battery to the phone and it would charge just fine whilst turned on. I left it plugged into the charger and it stayed on fine. I turned the phone off and left it unplugged only to find it was dead again the next morning. It would also not charge either, so repeated the battery charging again and it's now got the battery back in and is charging again, so two issues here, one.... It goes flat when not turned on and two once the battery is dead the phone won't charge it unless its turned on ?.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
There is probably a logic board issue with the power management chip. The logic board will have to be replaced to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Iain Simpson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 987
