跳转到主内容
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 个问题 查看全部
iMac intel front panel removal
What is holding down the front glass on a iMac A1225-2211 iMac 8.1 24"
Iunderstand you just remoce the glas by lifting it up. looking to find out what holds the glass in place and where the contact points are?
Ron.neufeglise@ctv.ca
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks for the info . It removed very easily
完成的
添加一条评论
4个答案
已选择的解决方案
I just used a couple of suction cups that were holding our soap dish to the shower wall. There is a guide at iMac Intel 24" EMC 2267 Glass Panel Replacement.
这个答案有帮助吗?
得分 2
添加一条评论
The glass is held by 14 magnets, thats why you only need 2 suction caps to remove it
这个答案有帮助吗?
得分 1
添加一条评论
Actually, you only need 1 suction cup ....
http://www.harborfreight.com/4-1-2-half-...
This is all I use, and for only $2.99 even! Best priced tool I have ever bought, use it for more than just iMac glass.
这个答案有帮助吗?
得分 1
添加一条评论
Even easier, I used a small piece of clear packing tape. Worked fine and left no residue. The amount of force needed is very small, just be careful not to break the pins by rotating the glass as you pull it off.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ron Neufeglise 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 3,999
