跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 个问题 查看全部
Dual SSD on iMac 21.5 mid 2010?
Is the Dual SSD replacement for the imac 21.5 Mid 2011 tutorial the same for the Imac 21.5 Mid 2010?
I've been searching and i always notice you refer to the mid 2011, but not to the Mid 2010.
I'm about to by a new SSD, but first of all, i want to be sure its able to replace it in my model.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You mean this guide?
Looks like a Mid 2010 to me.
This is a moderately difficult DIY repair. Purchase or acquire all the recommended tools (every job is easier when you use the proper tools). Study (not just read) the guide & comments before you begin - many DIYers damage machines because they don't unlock ribbon cable cams, or pull the wrong direction on connectors and end up tearing parts off the logic board.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so muchead3!! But of course i was going to buy the tool kit, i wouldnt be able to replace it then.
I meant this, if you read the title of kit, it says Mid 2011:
iMac Intel 21.5" Mid 2011 Dual Hard Drive Kit
I know its not an easy job. I've been watching videos, reading tutorials, and reading questions and answers other people could have had before they did it.
First of all, i want to have as much info as i can, to make sure i can replace it with no problems or worries.
I will mark your answer for sure!
Thank you!
完成的
添加一条评论
添加你的答案
Alvaro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,064
