跳转到主内容
针对近期推出的Mac笔记本电脑以及台式机的完全拆卸和组装指南。
42814 个问题 查看全部
问题已关闭
How to fix a stripped screw?
OK. On my MacBook 13'' which is broken, many of the Philips #00 screws are stripped. I try to turn them with slightly bigger screwdriver that has worked for them in the past, but the screwdriver just doesn't grip the screw hole. I don't have a dremel, nor do i have super glue easily on hand. what do i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I literally tried EVERYTHING. I tried the rubber band trick, holding down on the top of the screwdriver, i even tried a hammer to push the magnetic screwer in the void of the screw. NOW WHAT?!?
完成的
添加一条评论
1个答案
最有帮助的答案
Depending on how stripped the screws are, you may be able to put a rubber band between the screw and driver to see if it can give you some grip.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 332
