跳转到主内容
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150 个问题 查看全部
Changed LCD and Digitezer, now dipslay is black
Please help with this:
My Nexus cracked and the digitizer didn't work.
So I got a new LCD&Digitizer, replaced as per instructions - now Touch screen is OK, I can click and hear beep. The display however stays black. Sometimes I can see in the very dark something on it (the hour for example). Most of the time I see nothing.
Can you suggest what is wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
Try reconnecting the LCD cable, if not return the screen.
Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
Try turning the device off - then back on. That's generally the problem on other devices.
It sounds like your backlight isn't working. A simple restart will hopefully fix that.
这个答案有帮助吗?
得分 1
添加一条评论
I am having the same problem. Black screen after replacing broken screen and digitizer
这个答案有帮助吗?
得分 0
添加一条评论
I have found the solution. Change the lcd / video cable and it will be all fine then. Just did it today and it worked.
http://www.ebay.co.uk/itm/281198840636?s...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peppi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 283
