跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
The Computer End of the Thunderbolt Cable Seems to be damaged
One of my colleagues has a Thunderbolt Display that he uses with his MacBook Pro. Due to the way his desk is arraigned, there is quite a bit of sideways strain on the Thunderbolt connector where it plugs into his computer. The display no longer lights up, but the MBP power connector will charge the computer. Rather than replacing the whole cable assembly, would it be possible to just ignore the existing Thunderbolt connection and just use a longer separate TB cable that would fit his layout better?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The logic of connection is similar to FireWire and SCSI. So you shouldn't have any problem using the spare Thunderbolt port on the display with a longer Thunderbolt cable.
If you went to an Apple Store they would even test it out on their gear to be doubly sure before you bought the cable.
With that said it's possible the damaged Thunderbolt display cable could cause problems, so I would replace it just to be sure. This is a very easy fix.
Thunderbolt-MagSafe combo cable: Apple Assembly # 922-9941
Here's one I found on eBay USED 922-9941 All-in-one cable
这个答案有帮助吗?
得分 0
2条评论:
I'm unable to find any replacement guides using the part. Any links?
完成的
添加一条评论
添加你的答案
ershler 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,153
