跳转到主内容
The HTC Inspire 4G is the first smartphone available on AT&T Wireless branded as "4G". It's nothing more then an Desire HD locked to AT&T and running AT&T Software.
12 个问题 查看全部
How do you apply the 4 plastic pieces to LCD/Digitizer assembly?
I have a new LCD/Digitizer assembly that doesn't have the plastic pieces attached (the ones that light up the home/menu/back/search keys). How do those get put on without prying apart the new assembly?
Thanks in advance,
Jessica
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
You will probably need to transfer from the old unit. So whatever process you use to remove them from the old assembly, reverse to apply them to the new one.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks David,
Right after I posted that, I decided to try peeling off the clear adhesive that was still on the old digitizer and apply it to the plastic tabs. Then I aligned them above each key (home, search, back and menu) and slid them into place, pressing them down with a thin piece of cardboard inserted between the lcd and plastic tabs. It worked out :o)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jessica 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 151
