跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
What's wrong with my MacBooks's Screen?
As you can see in the picture, my MacBook (early 2008)'s right side of the screen has little dots
on the right side of the screen. My best guess is that the cable connecting the LCD to the actual computer has worn out. My AppleCare warranty is expired, so I can't take it in to the store. Do you think it is the cable? and if so, where and how can I fix it?
Thanks,
Nick
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Do you have an external monitor which you can connect your MacBook to? If you can give that a try and see if the same thing is present on the external. This model has an Intel GMA X3100 integrated graphics processor which is part of the CPU. It does share some of the main system memory as well.
If the problem is present on the external display then you should try swapping out the memory modules to see if the problem is bad memory, otherwise your processor chip is going. If the external display is OK then you'll need to look at the internal display and the display data cable and/or the connectors.
The cost of replacing the logic board or the display is quite high given the age and limitations of this system. You may want to look at getting a newer system.
这个答案有帮助吗?
得分 2
添加一条评论
I doubt it might be the cable itself because on my Mac mini the cable gets disturbed even by a small disturbance causes strange turbulence to the screen. I have to remove & reattach the cable and also make some adjustment to put it right back. But if the cable is fine then do what Dan suggested. Connecting to an external monitor will clear the picture.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick Baker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 227
