跳转到主内容
Placement order of diffuser sheets?
I'm replacing the screen on a friend's MBA (A1370). Upon removing the broken LCD from the bezel, The 3 sheets of plastic behind it fell out and spread on the floor. Is there a particular order these must be put back in? I'm guessing they must have an order of some sort. Otherwise it will be hit and miss, Trial and error.
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
its a very difficult one to describe in words, but the white backing sheet is obviously first, then the thickest plastic sheet lines up with the LED strip at the bottom... then the last few need to be put in order as well. The one with a darker shade, and an almost matte finish is the last one, so the more metallic reflective one goes in-between the thicker one and the last one...
i hope this helps.
这个答案有帮助吗?
得分 1
2条评论:
I've got the same issue. I can't quite understand what order they go in. Can somebody help me with front to back placement - front being closest to the screen? Thanks.
完成的
Indeed this seems there are only 4 components but my kit came with 5 sheets. Can you please help us figure this out?
完成的
添加一条评论
添加你的答案
Djdat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 3,307
