跳转到主内容
PlayStation 3 Slim是Sony Computer Entertainment生产的PS3视频游戏机的第二版。 它于2009年9月1日发布。
467 个问题 查看全部
PS3 Slim Overheating after cleaning and thermal paste replaced
Hi,
I have been playing FFXIV ARR and the screen kept freezing. So I did some research and some people say maybe is because the PS3 is too hot. So I look up youtube how to open my PS3 and clean out all the dust and the fan. After that I put it back together and my ps3 started saying overheated and shutdown by itself. So I did more research and thought that it could be the thermal paste is too old. So I researched how to replaced the thermal paste and I reopen my PS3 and change the thermal paste. Didn't know how much to put I put quite a lot and reassembled it and used it again. Got overheat again and asked a few friends and they said maybe i put too much so I open it and cleaned it out and put less. I'm using Artic5. now the PS3 still get overheat. I do not know what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
open it again,use the spread method first and when u have spread the thermal paste add a pea sized thermal paste in the middle of the chips..then bent the clamps that tighten the heatsink and screw them on the board..you re done..
see from 1:54 to 3:38
thermal paste application
这个答案有帮助吗?
得分 0
添加一条评论
Thermal past is only half the battle, having a good amount is the key goal, but also having good air flow, and a good fan is what keeps it cool. Check to make sure that you have it cleaned out for the intake areas then make sure to do the super blow out method as shown on other youtube videos where you hold the eject button down with everything unplugged but the power, then plug the power in and after a few seconds let the button go. you should hear a high powered blast of fan, if not then you might have a bad fan or even worse connections to the fan could be bad.
Here is a simple video before going extreme, maybe this will help too. https://thewikihow.com/video_LiEZgzktsLo
这个答案有帮助吗?
得分 0
添加一条评论
It's ok if many ,the problem might be on the inside if u delid the cpu or RSX , they have built in ihs whick might be dried
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Remiel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 42
总计 9,338
