跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
Generic replacement screen won't power on but cracked OEM screen works
Hey everyone, I am having an issue with a generic replacement screen for an ipod touch 4th gen. I have repaired many iphones and already done an ipod touch 4th gen. My current issue is as follows:
I replaced the screen (complete assembly) and now the ipod won't power on or be recognized in itunes or show the battery charging sign when plugged in. The interesting thing is that when I reinstall the old OEM screen (cracked) it will work completely. The ipod will accept 2 different cracked OEM lcds that I've tried.
Before you say bad LCD, this is the 3rd replacement LCD I've tried all had the same prob. when the cracked OEM screens are on the comp will recognized them and the screens still work. However when the generic replacement is installed it won't power on at all.
Please drop some knowledge on me.
PS I called a repair shop & the guy said he on a rare occasion will get an ipod that won't take generic screens. does that sound right?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Just in case someone is reading this months later to try and solve their own problem I am letting you know what happened.
Long story short, I went through about 3 defective lcds. I went to a different seller and it worked just fine.
Good luck repairing.
完成的
添加一条评论
1个答案
That is not true. I have NEVER had any iPod that would not work with a replacement screen and I have done a ton of screen replacements on these iPods. When the iPod display is not working can you see it when plugged into a computer?
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the response.
No water damage. As previously stated it works fine with 2 different cracked OEM screens.
I'll try another seller; like I said wierd that 3 different screens make it unresponsive when the OEM works fine.
I was just wondering if anyone had a similar experience.
完成的
添加一条评论
添加你的答案
israel orelana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 181
