跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
MacBook wont power on after replacing broken screen
After replacing a broken LCD on a mid-2013 Macbook Air using the instructions found here, I am unable to power on the Macbook Air. The logic board seemed to work fine before the replacement. Now it will not power on at all, and when connecting a known-good power adapter, I get no light on the mag connector, either green or amber. Was the logic board damaged during the replacement, or is there anything else I can try? I've gone through the steps in the instructions a few times to verify that everything is reconnected properly. Thanks for any help you can give.
- Chris
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
First thing after a big repair would be to make sure everything is connected, after that you may want to try and reseat the connections as well if it still isn't working. I ran into a problem where the power button wasn't working after a trackpad repair and reseating the cable for this fixed it. Also an SMC reset can be tried as well.
Ps. Remember to use electrostatic protection during computer repairs. If you don't have a wristband, make sure you are touching something metal during the whole repair.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the advice. We had tried an SMC reset to no avail. This morning I asked one of my techs to take another look at it and it powered on fine. We suspect that the battery fully drained causing the laptop to reset itself in someway. Unfortunately, the backlight on the replacement LCD is out, so I'll have to file a return with iFixit.
- Chris
完成的
If the unit is a liquid damaged machine you may also suspect a blown backlight fuse on the logic board. I don't know where the backlight fuse is located on this MBA model but if you find it try a continuity test on the fuse with a multimeter.
完成的
添加一条评论
添加你的答案
help 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 1,755
