跳转到主内容
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 个问题 查看全部
The tray going open and close by itself sometime
my xbox 360 slim 4gb tray going open and close by itself
and sometime or most of time power button dose not work i should turn it on bu my controller .but the worst problem is open and close tray by itself . plz help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
The other possibility is the open/close sensor that is attached to the front underside of the drive. It is a little switch held by two plastic clips and has three wires going to it. If one of the clips breaks (which occurs often), it cause the sensor to drop to an angle and the tray does not trigger the switch everytime. You would need to put electrical tape or foam under the sensor to keep it held in place.
这个答案有帮助吗?
得分 1
添加一条评论
The touch switch flex cable could be damaged. Replace the cable
这个答案有帮助吗?
得分 0
2条评论:
Which one is flex cable mate?
完成的
the ribbon cable attached to the faceplate, it senses touch actions
完成的
添加一条评论
添加你的答案
hesam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 2,425
