跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
问题已关闭
Fan speed to the max after superdrive replacement with SSD
I tried to install a second SSD drive in my iMac 27" (mid 2011). I followed the guide to install it to the free SATA port only to find out that I was missing the connecting cable. So I assembled back to the part that I had to place the superdrive and I used a caddy (which I already had) following the instructions here.
I closed the computer and installed Mavericks and found out that the fan was working at full speed.
I did transfer the thermal sensor from the superdrive to the caddy. Does anyone know what could be wrong?
I when through all the cables to check if anyone was not correctly in place and still have the fan at full speed,
Other than that the iMac is working extremely fast and without any other problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I don't think you can use the optical drives cable as the system is expecting an optical drive on the other end.
I would recommend getting the correct SATA cable and see what happens then.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 423
