跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iTunes Givng Error 16
Hello, I have an iPhone 4 GSM 8GB model that I got from my friend and my Telus sim card (Also the carrier fir the phone) was not being recognised so, I automatically thought that I should do a factory restore, so I did but it just gives me error 16. I have tried EVERYTHING DFU mode, restore mode, PWNdfu mode, everything. And I still get error 16.
I have the latest iTunes, Windows 8.1 and I'm trying to restore to iOS 7.0.4
Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Error 16 usually points towards a hardware/ cable issue, try using a different data cable, or leave the phone plugged into the PC for a hour or 2 then try again. If all else fails take it to a repair shop so they can test internal components.
Same happened to me and it turned out to be the lock button flex causing a short.
Good Luck :P
这个答案有帮助吗?
得分 0
添加一条评论
Anyone got more info on this? have 2 mainboards with this problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Koston Morin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 7,064
