跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
Touchscreen works, but display is dark. Can I fix it?
After the phone fell from my pocket onto a tile floor, the display went black. For a while I could see a few thin, faint horizontal lines at the bottom of the display, but then those went dark, too.
The touchscreen still works. I can answer calls (if I swipe in the right part of the screen), take pictures (if I can hit the camera icon blind), and so on.
I used the disassembly guide to locate the display data cable. I pried it off gently, then snapped it back on and reassembled the phone, but no dice - it acts exactly the same. What else could be the problem? Is it fixable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
LCD is broken.
Samsung galaxy S3 LCD screen and touch screen, they are one and the same.
You need change it. Probably $ 132.
这个答案有帮助吗?
得分 1
添加一条评论
Yup, as Chloe said, LCD was damaged, you can replace the LCD+touchscreen+frame, which can make your repair much easier and less risky, S3 screen replacement is not that expensive now, it costs less than $80, check it out: http://www.etradesupply.com/oem-samsung-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrea Reese Hurst 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 1,041
