跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
External speaker issues with volume increase
Here is a weird one for you. The external speaker on my iPhone 5 began to exhibit a static like crackle when any sound came through it that quickly turned into it not working at all. Read a bunch on this issue online and tried all the recommended fixes to no avail. After much research, I determined that replacing the headphone jack was probably the solution. I have ton's of experience working on small scale electronics, soldering, etc. so after purchasing a new headphone/lightning jack hardware from ifix it and installing it via the helpful guide, success! Speaker worked and I was so happy. But upon moving the volume level up past the 3/4 level, speaker crackles and stops working and won't work again even after system reset and lowering the volume. Take it apart again, make sure all the connections are seated properly, put it back together and speakers work but cut out again if I move past 3/4 level. Any ideas on what could be causing this? Repeated this procedure a total of 3 times with exact same result. I'm careful to use a grounding wrist strap when working on things and am truly baffled.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
It sounds like a possible watere damage problem, check the stickers inside. If not it might be a bad part, I'd send it back if you can and go through where I went because the part I got worked great..
used this iphone video
这个答案有帮助吗?
得分 0
添加一条评论
Check whether the Ring/Silent switch on exterior of iPhone 5 is switched to silent mode. This is a common factor causing iPhone 5 no sound and many of you may miss it. Flick the other way to the Ring mode in this case.
If this tip can't help you, I believe you must can find the fix you from this article
iPhone 5 Speaker Not Working – Top 10 Options to Fix It
这个答案有帮助吗?
得分 0
添加一条评论
There is no solution I have searched and searched but I noticed when u suck air from the bottom where the speaker lies they start working again though not as new but as those lame ass put my volume up ill stop working speakers. I am surviving in this state so if anyone gets a fix without mentioning the ringer it would be totally helpful
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Carroll 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 5,801
