跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
Replaced battery and now touch screen is non-responsive, why?
I plugged my iPod into the wall and it turns on just fine but when I take it off the power shorts out. I replaced the battery and now the iPod turns on but it doesn't respond when I go to unlock it. Did I forget to connect something inside the iPod?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
to answer your last question - yes - i think so.
the connector for the touchscreen is n the top left, since it is so small - there is no real "feeling" about plugged or unplugged
open it again and check the connection (see step 8) - thats the connector
这个答案有帮助吗?
得分 1
添加一条评论
I had the same issue. I know the connector was nicely seated, because I lined it up carefully and it snapped easily into the socket. However I had torn the front panel ribbon cable on disassembly and didn't realize it. So, now I'm ordering a new front panel assembly. Luckily the entire fix is still close to what a factory repair would cost and I have gained the experience from my disassembly mistake.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
warnerd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,795
