跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
How can I fix dents on the side of I phone 5s
http://www.youtube.com/watch?v=gWzqcjEbn...I drop down my iphone from 1 meter high and its dents on the side , i am thinking to find some same color paint and pain it but the surface is not flat anymore
Any ideas
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
I have the same problem as yours, I remove the case and I accidentally dropped it from about 1 meter from my hand, but I don't know how to remove the dent.
完成的
Yes, that exactly same thing happened to me last tuesday :/ I was so mad to myself, because I just bought the iPhone 7 and already dropped it while I was cleaning it with a cloth. So, I remover the case for like 5 minutes and I managed to drop it
完成的
添加一条评论
2个答案
已选择的解决方案
As long as the phone is still working I would leave it alone. If your phone is not working then you might be able to get a replacement under the extended AppleCare plan.
If this really bothers you see if you can get a case that covers it up. Paint won't stick to the metal very well and besides you would need to paint the entire edge so the one spot doesn't stand out. In doing so you could effect the phones operation (plugging up the mic & speaker holes)
这个答案有帮助吗?
得分 1
1条评论:
Thanks
I have ordered same color pain and will paint it, i dont like it really
完成的
添加一条评论
Hi. I have the same problem as yours. I dented mine using a bandage scissor. then tried fixing it but instead got a scratch on the side of the dent. I guess you just need to cover the phone up. minimal damage is enough. and try not to look at it. that lessens the pain we feel. buy something that covers up the sides and back, and ignore it. :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stepan Petrosyan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 15,281
