跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
iPad Mini Home Button not working after digitizer replace
I replaced the digitizer on an iPad Mini and now the home button doesn't work. Not to be mistaken for the issue where the home button thinks it is always pressed. It is not responding at all. Anyone??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
Have a look at this thread: iPad Mini Home Button Not Working After Digitizer Replacement
the answer was given by GtechRepair: "The easiest solution Is to go back to the old screen at the bottom where the Home button is located, There you will see two pieces of fabric tape, The one closest to the home button will be layered over a clear piece of tape, try to remove them together, use x acto knife to lift up corner, then a good pair of tweezers to peel it off.
Perform the same procedure To the fabric tape to the left, Then place both pieces down on your new digitizer, In the same place that they were in on the original. This should solve your problem 100%."
these black tapes go here:
这个答案有帮助吗?
得分 2
添加一条评论
Same here :(
这个答案有帮助吗?
得分 0
1条评论:
Im going to try a new digitizer assembly when I can. Have you tried this?
完成的
添加一条评论
Same issue
这个答案有帮助吗?
得分 0
添加一条评论
NICE.. SWEET! (If only I hadn't thrown that old broken digitizer away :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gavin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,639
