跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Black screen after replacement
I just replaced cell signal antenna and the power-button/sensor cord and I adjusted the home button, cause it was too tight.
After I was done and put it all together, the screen was white on one half of the screen and black on the other half, after 10 seconds the white faded away and it all got black.
I then turned it off by holding home and power button, then I whiped the LCD and digitizer connectors with a piece of paper, I also replugged the battery connector just to be sure.
When I reassembled it again, the screen wouldn't even turn on at all. To make sure it actually was on, I Connected it to the PC, it turned out to be on, but the phone speaker itself made an beep noise every 5 seconds while Connected to the PC.
What has happened?
Update:
I cleaned the connectors again with Windex on a Q-Tip.
Now it's just back to black screen, but atleast it's on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You may have damaged the LCD cable of your screen. did you try another screen?
这个答案有帮助吗?
得分 1
1条评论:
Can I try another screen without the replacement procedure, just attach the cables?
完成的
添加一条评论
添加你的答案
Mats 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 469
