跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
How to permanently disable wifi
Want to disable WiFi but still be able to make calls and send text. If I remove the WiFi antenna and do not replace it, when reassembled (without WiFi antennae)will I be able to still make/receive calls and text messages? Do not want to just temporarily disable WiFi. I need to remove and permanently disable it. Thank you for any assistance you can provide
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
That should permanently disable wifi without interfering with any other functions of the phone except for bluetooth because the wifi and bluetooth antenna are one part. If it does happen to interfere with something else, you can always reinstall the wifi antenna.
这个答案有帮助吗?
得分 1
7条评论:
Thank you! Your help is appreciated
完成的
I tried this and I still have wifi without an antenna! How is that possible? What else can I do to disable wifi?
完成的
I am trying to disable wifi on an iPhone 4.
完成的
Just because you disconnected the antenna doesn't kill WiFi services (or any other service you pull the antenna) it only limits the range of the signal.
完成的
I don't know of any way to permanently disabling WiFi here other than disabling within iOS its self. Maybe if you explain why you need to do this we could try seeing what options you have.
完成的
显示更多的2条评论
添加一条评论
Put a restrictions code on it believe me he won't find a way around it if is entered wrong to many times it locks him out of phone
Update
Or look for a iPhone 4s with greyed out wifi forsale these are going really cheap
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 5,997
