跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
问题已关闭
Formating Error on Second harddrive
I just installed my upgrade kit (this) and a second harddrive instead of the dvd-drive. The Drive appears in the settings, but when i try to format or erase it i get the following error:
"wiping volume data to prevent future accidental probing failed "
i also tried to boot with the tools, but the same error occured
Unibody Laptop Dual Drive图片
产品
$24.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
originally there was a 256GB Cruicial M4, now i added a 1 TB WD Red in exchange for the dvd-drive.
完成的
That drive was not on the list of possible suspects. Now you know why.
完成的
so would it work if i switch the postions?
完成的
Are they not the same size? I will test tomorrow
完成的
The one I looked at spec'd a 3.5 in drive,,, your OEM is a 2.5 inch… I think you'll also get overheating/battery life issues with that large of a drive.
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
Kit says: Does not include hard drive. We recommend a 240 GB SSD, 500 GB 7200 rpm drive, or 750 GB hybrid drive. What drive did you choose? The problem could be the drive. Or the cable.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 312
