跳转到主内容
问题已关闭
computer stays at start up page
i recently lost all my photos on my apple mac, since then i have recovered them using a mac recovery program, unfortunately it recovered ALL the photos since i have had it including deleted files.
i got all my files back, but then my computer would not turn back on after being shut down, staying at the start up loading page before log-in, i need a way or know how i can remove all my files off my computers hard drive.. do i need a cable or a program or is there a reset code which will restore without loosing media etc??? HELP ASAP
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
NO RESET you don't want to loose all those photos again! If your disk is more than 80% full you need room for VMEM and swap files…that could be why your boot process hangs if you can remove a RAM chip just until you can immediately delete some large useless files you can later replace (movies, music) once you get your house in order. With less RAM that requires less free HD space you might be able to boot into safe mode to accomplish this.
If you disk is not that full you may have a damaged master account. Sometimes starting in single user mode and doing a force check (fsck -fy) can repair that damage. OR starting from D and repairing the disk and disk permissions may allow you to get into your account, in safe mode.
What you have to do is 'no new activity until enough large files are moved to the trash and the trash emptied to allow you to reboot normally.
Only other option is to boot from some other source (Disk or Mac) connect your drive via Target mode or external case and clean up the large useless files.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 82
