iPhone 5 front camera wont work after front screen replacement.
I run an iPhone repair business in the UK, so I do have a reasonable amount of experience with these devices and until iOS 7 came out I had no issues with this problem I am about to explain. A customer came into the store yesterday with a broken screen and power button on the iPhone 5. So I replaced the power button flex to fix the button and replaced the screen with an original part. But then when I turned the phone back on everything worked perfectly apart from the front camera. I have sent my customer away to restore the device and then Im sure he will be back if it doesnt work, but does anyone know a fix for this? (I am always extra careful when removing the digitizer and camera flex cables, and yes I have checked if its plugged in correctly three times.)
4条评论
Guys, I have a question that has been bothering me ever since! My iphone 5 (black) has no front flash! Is it normal? I see other phones having flash infront of their camera, but mine has none. Please tell me it's normal
由 imrheacarino04 完成的
Well most ppl have snapchat and for the front facing camera it will flash the screen white similar to a flash so it's normal
由 Matt Mock 完成的
well i have an iphone 5c and i got the screen replaced and my front camera has not been working every since when i clock on the camera app and try to turn the camera to the front camera it automatically turms back to the rear camera i tried turming my phone off it still doesn't work
由 karla 完成的
I had the same problem, I removed again the battery connector, put it back and it works now.
由 Paul Poenaru 完成的
