跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
802.11ac Wi-Fi card fits 2012 model
Will the Air port 802.11ac Wi-Fi card fit into a 2012 15 inch retina MacBook Pro? or if it fits will it work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
So far Apple has released two different AirPort boards for the laptop systems. The first one had two antenna connections and the newest model has three. Then there is the issue of the antennas them selves. The size and placement of the antennas is also very important otherwise they will not work properly (limiting your throughput). As these systems are so new no one has made the needed studies to fully understand what Apple has done.
You might want to review this thread Will it work? As you can see there is a bit of debate on the subject ;-}
In any case the part is still not available and I don't think it will be for quite sometime as Apple will eating everyone that comes off the assembly line.
OK, So lets say you got one, and lets say the antenna's will work. Do you really need that kind of throughput? Most of us just don't have internet connections that could even push 1/2 as much down. Now, if you had your own server to access then you might but that also means your server is setup to offer out that much of a stream. Again, most of us just don't have RAIDED systems that could do this.
Don't get me wrong here. In the future we will likely have this level of throughput but thats still a good five years away.
Bottom-line here save your money upgrading your AirPort board to an ac version.
这个答案有帮助吗?
得分 0
添加一条评论
I would like to know the same answer but for a 2010 MBP 13" C2D 2.4 ghz and an iMac 27" i7 2.93 ghz
Looking at ifixit teardown of the iMac yes in a sense they look the same compared to the new 2013 model teardown
i hope some one can let us know asap and then were to get the new ac wifi card. i know that the new wifi card has bluetooth 4.0 in it and my model has it separate which i dont really care for the luetooth stuff
这个答案有帮助吗?
得分 0
添加一条评论
The new Airport card (802.11ac Wi-Fi) in MacBook Pro 15" Retina Late 2013 is compatible with MacBook Pro 15" Retina Mid 2012.
You can look at under site.
http://cafe.naver.com/inmacbook/916510
这个答案有帮助吗?
得分 0
2条评论:
You may want to translate the Korean text first. It appears they to have the same questions on it working. "Down to the newly purchased Airport Card BCM94360CSAX 802.11a/b/g/n/ac support. (I live in China, and the products are still very much in place seems to be unsolved). Supporting 802.11ac MacBook Air, Mac Mini, iMac with Airport Card, such as the shape and number of antenna ports is the difference."
完成的
It works very well and still using ac mode without problems.
But, My router is RT-AC66U and supports 1.3Gbit/s with ac mode.
Link speed indicated 1 Gbit/s on the network utility's informations.
完成的
添加一条评论
QuickerTek has the 802.11ac cards for 15" MPR and 13" MBA
这个答案有帮助吗?
得分 0
4条评论:
I want a new Airport card (802.11ac Wi-Fi) for the late 2012 Mac Mini 2.3Ghz quad i7. It would seem that would be the most flexible Mac for a fix like this.
完成的
Checkout this web site: Continuity Activation Tool
完成的
I received only a 404 message from github. Is this one of those Lisbeth Salander-type tricks where I have to click the right '0' in the message to get into the site? Just kidding.
I'm used to Apple Mac and Windows PC automatic wizards, so I hope that I don't have to learn how to read Chinese-character system pages. I can't even recognize "OK" or "NEXT" buttons in Mandarin. So I'll lurk here and at the Android Developers sites to learn how the Android OS works and is organized, before I'll ever risk changing a thing in my Onda V989 tablet.
完成的
My bad ;-{ I cut off something in the pasting of the link. Try this one: Continuity-Activation-Tool
完成的
添加一条评论
添加你的答案
cgonzalez19835 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 36
总计 14,733
