跳转到主内容
加入维修社区 - 创建账户
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Nvidia discrete graphics GPU
I wonder if the Nvidia GPU is soldered on the motherboard or is it an add on card? There seems to be no extra room for an add on PCIe card
I wonder if for the base rMBP it is just disabled...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes there are two distinct versions of this system:
The low end version just doesn't have the NVIDIA populated on the logic board and the higher end models which has the chip.
GeForce GT 750M and Intel Iris Pro Graphics with memory shared with the system.
The system automatically switches between graphics systems based on use (when applications use OpenGL, Core Graphics or other graphically demanding technologies, the system will use the dedicated graphics card, otherwise it will use Intel HD Graphics to conserve battery life).
这个答案有帮助吗?
得分 1
3条评论:
So there is still no option in Mavericks to "force discrete"?
完成的
Why would you do that? Don't you want the best graphics engine for the task? You can lower the screens resolution which will do that.
完成的
If you check the logic board photos or board views for the rMBP Late 2013 you will note that the logic board with and without GPU differ a lot. That is the reason also the heatsinks are different in these two models.
完成的
添加一条评论
Placing the GPU on a card adds thickness, Apple never made any laptop GPU removable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,262
