跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20000 个问题 查看全部
MacBook Pro will *only* run with disconnected battery
Ok, so, my friend spilled a scotch and soda on his mid-2009 Macbook Pro, and I'm trying to suss out the extent of the damage.
The computer will boot and run normally off of AC power with the battery disconnected. With both the battery and AC adapter connected, however, the it will shut down halfway through the startup sequence (after the chime, but before the grey Apple logo.) Furthermore, if I reconnect the battery while the machine is up and running, it will shut off immediately.
(Also, the battery test button does nothing, no matter what is connected or not.)
So the question I'm left with is whether it's the logic board's battery-in port that's problem, or if it's just a bad battery. Obviously, the ideal next step would be to see if the machine starts up with a known-good battery in place, but I unfortunately do not have one to try it out with, and I'd rather not spend the money to buy one, only to find out that it's useless because the MBP's logic board is faulty.
What do you think the likelihood is that it's only a faulty battery causing the shut-downs? Is it worth risking the $150 to find out? Or is it pretty much certain that the logic board is bad?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Some of these laptops will not boot with a bad (-25% charged) battery. But will boot and run slow off the charger only. Examine the logic board around the battery connector under a magnifier for corrosion or burnt/swollen components.
At that age a new battery would be appropriate. I guess you'll have to price out the cost of fixing the port/logic board vs just a battery.
If the new battery isn't the fix you can part out the machine and the new battery to recover some $ for a new(er) laptop.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Jaime 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 4,483
