跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
问题已关闭
Do I Need to Replace my Control Board?
Earlier today, I was playing MotorStorm: Apocalypse. When I was done, I quit the game and went to eject it. It would not eject. I noticed the LED lights were not on. I ejected the game via XMB. I then shut off the system as I usually do with my controller. I went to turn the system back on, but it wouldn't. There was no LEDs again. I figured I had a PSU failure after reading several articles, posts, etc, so I purchased a spare PSU online. Afterwards, I began reading that the problem may be motherboard related and could actually be YLOD. One thread said one way to figure that out is to put a disk partially into the disk drive to trigger the system. If that happens, the motherboard is the problem. Sure enough, that's what happened. I tried a second time, this time with my HDMI plugged into my TV. The system booted fine, using the disk method. And if I had YLOD, I don't think I would've been able to play all my downloadable games (I'm not risking putting a disk based game in just yet). I could even use my DualShock 3 to turn on/off the system. It appears the fault is with my control board in the front of my system. Everything seems to work except for the i/o button, the eject button, the front LED lights.) I saw the guide here, but the control boards are sold out. Does anyone have suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Its most likely the ribbon cable that connects the control board and it can be replaced for $2
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 217
