跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
20 个问题 查看全部
Are the Cellular Antennas necessary?
I received a freebie ipad2 that someone had attempted to replace the digitizer on. They had scraped out some of the glass at the top right where it broke, and in doing so, damaged the right cell antenna.
However, I'm not planning to connect it to a cell carrier, simply use it with wifi around the house.
So, my question is, will it cause issues to leave that broke? Or should I just replace?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The only way to find out is to test it. Maybe the damaged area works on a different band, or it is the GPS one or the damage does not impact performance. In the case that there are impacts, replace it
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Aaron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 144
