跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
2012 13" MacBook Air with 2013 battery compatibility
Hi,
I got a 500 cycles battery from a 2012 13" Macbook Air and I'm thinking about replacing for a new one.
It is said on the store from this website that the 2013 13" Macbook Air battery is compatible with the mid 2012 model.
I noticed that the 2012 model has a 7.3V vs a 7.6V from the 2013 models.
Is it OK to replace it considering this voltage difference?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Yes - that's what "its compatible" means.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 0
添加一条评论
the description of the 2013-battery states:
"Replacement battery compatible with all 1.3 or 1.7 GHz (Mid 2013), 1.4 or 1.7 GHz (Early 2014), and 1.6 GHz or 2.2 GHz (Early 2015) 13" MacBook Airs, and backward compatible with 1.8 or 2.0 GHz (Mid 2012) 13" MacBook Air."
and that says is all.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
victor hugo Cruz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 971
