跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 Front camera dont work after screen replacement
Hi everyone, i did a screen replacement of my iphone 5 but after that the front camera doesn't work anymore, i tried to reseat the connector but steel not working, could i screw up the logic board? help!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
I have two like this and it is board damage at the very edge of the board.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
you probably damaged the front camera flex cable. they are very fragile, replace and your camera will be fine
iPhone 5前摄像头及排线替换
这个答案有帮助吗?
得分 1
1条评论:
should it matter if the earpiece and the brightness adjuster still working?
完成的
添加一条评论
i bought a replacement camera from ifixit as well and did the replacement, they don't work. the camera when turned on just gives a small glimpse of what it sees and then freezes, do you know what the problem is?
这个答案有帮助吗?
得分 0
添加一条评论
It seems you break the cable of front-facing camera. Can you describe more detail about the front -facing camera.
这个答案有帮助吗?
得分 0
添加一条评论
Does the back camera work? Some times if back cameras broke it won't cycle to the front camera
这个答案有帮助吗?
得分 0
2条评论:
Jess do you mean damage around were the camera contacts to the motherboard?
Fire up a few pics and Jesus can compare
完成的
Yes--there is a row of very tiny SMD components between flex connector and board edge.
The other had damage to another tiny component on the other side of the connector. I will try to post a pic later
完成的
添加一条评论
添加你的答案
Jesus Ruiz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 6,747
