跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
Lost bottom screws and clearance after repair
After I swapped my touchscreen and the rear panel I lost the screws for the bottom of the iPhone. Now I want to buy some knew ones and need to know the exact specifications. I also have problems with the clearance between the rear panel and the metal frame, which might be due to the absents of the screws. Has somebody some experiences with that. I fear that I bought some low quality rear panel.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi chrisp,
I recommend buying a set of new screws. You get them here for under $2.
The clearance issue might be related to the missing screw(s). However, I would double check (and partially disassemble the phone again) what the real issue is. And when the new screw set arrives, I would give it another try.
Steffen
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 228
