跳转到主内容
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
124 个问题 查看全部
Display - Screen colors go fussy
The display screen on my Samsung Galaxy Note 10.0 note goes fussy and the screen does not always respond to touch. I don't know if it is the screen only or the digitizer. The tulips are my screensaver and what happens is that the edges of the tulips start becoming fussy and the colors start changing. Please let me know whether I should buy a new digitizer and if so please let me know how to install it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
That sounds like the LCD. The digitizer wouldn't change any coloration. Also take in to consideration if you left this device in the direct sun for a long time or in a vehicle it may be a GPU overheating issue. If not. I'd say LCD. Just my opinion. Good luck.
这个答案有帮助吗?
得分 0
3条评论:
I had this same problem of fussy colors. I left it in my car facing the dun for long. How do I get my right colors back?
完成的
I need advice for my samsung note 10.1. Mostly fuzzy screen and blue shadding around pictures. My blue screen for the signing in to samsung is now green.
完成的
I am having similar problem as the last comment with my Note 10.1. The screen is mostly fuzzy with a royal blue color around pictures/objects on the screen. Can this be repaired? Grandma Sil
完成的
添加一条评论
I faced the same problem before. I sent it for repair and the technician said it was due to a flex cable problem.
After replacement, it can be used as normal.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julie Dobbs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,359
