跳转到主内容
加入维修社区 - 创建账户
The HP Photosmart Premium All-in-One printer can be used as a printer, copier, scanner. This printer uses a 5 color print system.
paper feeder won't suck in paper
paper feeder won't pick up paper, I need to push paper in myself to let the roller suck in the paper.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Over time the paper dust causes the feed rollers to loose their tackiness to grab the paper.
What you need is a rubber revitalizer which is a blend of special cleaners and anti-oxidants to rejuvenate buna-nitrile, EPDM and other composite rubber feeder rollers. Kenetix Rubber Revitalizer is one product you could use to clean the rollers.
If you have a silicone rollers you can use a good quality of Isopropyl alcohol to wipe them down.
这个答案有帮助吗?
得分 1
添加一条评论
Could also be the same problem as described here :
Paper feed rollers have stopped feeding paper?
The Gear on the silver rod was "destroyed" inside - so it can't push the paper (doesn't turn with the silver rod when "loaded" with paper. The solution provided by Benjamin was perfect for me.
这个答案有帮助吗?
得分 1
添加一条评论
It may be the rollers are not turning at all. Worth checking with a flashlight.
That is my problem on a 7510 Photosmart.
这个答案有帮助吗?
得分 0
1条评论:
My problem also. rollers not turning on 7510.
完成的
添加一条评论
添加你的答案
Will 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 5,948
