SSD instead of ATA SuperDrive
Hi, I decide to install a primary SSD instead of my SuperDrive in my old 24 inch , 2,4 C2D . But it's a ATA interface for the SuperDrive . Is it slow down SSD or be
Okay? My plan to install system on the SSD and all files
On to the HDD- SATA.
Please let me know if someone did it before
Thank you
2条评论
I just install SSD instead of Superdrive and keep my HDD in place.
Installed system on the SSD . Performed system performance test, SSD read and wright is not more than 50MB per sec. Looks like that slow than HDD.
HDD performed at 70MB per sec. Any Ideas how to improve a speed?
Thanks
由 Vitali 完成的
You'll need to swap the drives around putting the SSD where the HD is now located to gain the sped benefit of the SATA port. Then put the HD in the Optical drive carrier which has a slower PATA port. While it would be nice to have two higher speed SATA ports you're stuck here with one slower PATA port.
由 Dan 完成的
