跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
iPhone only works with plugged in on ACC
Hello!
I have the Problem that my 4S doesn't work.
Only if I plugg in the ACC-Adaptor and after that all is working fine.
Without the Cable or in an normal USB-Port it doesn't work. Only the Apple Symbol appears for a few seconds, than the Screen is black for a few seconds and than the Apple Symbol appears and so on and on.
What can I do?
Did a DFU Mode will solve the Problem?
What do you think?
Thank you for your Help.
Regards,
Thomas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Triede to replace the battery?
Its either a problem with your battery or the connection between the battery and the board.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 81
