跳转到主内容
My superdrive is not picking up any disc
Hey,
My macbook pro 13 is just an year old and my super drive was working fine - last used 2 months back for installing windows 8 through bootcamp.
But today my super drive is not picking up any disc neither new nor already burned.
Exactly -- When disc is pushed inside, it tries to read it. Motor makes a sound and after 4-5 seconds it comes out.
please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Sounds like it could be damaged. Verify that the same problem exists in WinDUHows... if it doesn't it could be a boot camp, WinDUHows issue. If it does then it seems the drive has failed. This happens. DIY replacement (there is no DIY repair for these drives) is something you have to decide upon.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
2条评论:
yes the same problem exists in windows bootcamp also!
i bought mbp an year ago and haven't used it much, there must be some way.
Is there anyway to DIY (as you mentioned i have to decide upon?) if not then what are my other options?
完成的
If you have Apple Care talk to Apple. If not you have to replace the drive. Only you know if you can DIY or if you have to pay someone else. If you do it- purchase the recommended tools. Every job is easier when you use the proper tools.
完成的
添加一条评论
添加你的答案
Jaswinder SinGh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 200
