跳转到主内容
The Logitech Harmony One is a universal remote by Logitech that was released in 2008. Logitech Harmony is a line of remote controls and home automation products produced by Logitech, an American-Swiss manufacturer of computer peripherals and software.
3 个问题 查看全部
Where can I purchase a replacement LCD?
My Harmony One remote fell face-down on tile floor and the LCD now looks like a work of modern art. I called support and was disappointed to learn that they do not repair their own products, nor do they have any information about 3rd party repair places. They also don't sell replacement parts (shocker). All they offer is a 3 month warrantee that replaces broken products... Well I've had this remote for a year and a half and was really hoping to keep using it!
So does anyone know where I can buy a replacement LCD for the Harmony One? After looking at the excellent teardown here I think I could handle the fix myself if I had the part... I know it's a longshot, but I had to ask! Thanks ifixers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
I have this same question. I saw a Youtube video that it needs to match PA 7.4 but I cant find that P/N anywhere.
完成的
添加一条评论
7个答案
最有帮助的答案
Short answer: Nowhere! :(
Longer answer:
I was searching for more than a year and it seems not to be possible to get this $%*§ display. Logitech wants to sell new products, they don't want to repair old ones, and they also don't want others to repair it. The display was produced for H1 only, and cancelled with the end of H1.
Please read this for more info:
http://forums.logitech.com/t5/Harmony-Re...
Or also this:
http://www.harmonyremoterepair.com/H1-Pa...
Sad greetings.
PS. sometimes you can find spare-remotes on ebay, this seems to be the only chance
这个答案有帮助吗?
得分 1
添加一条评论
First, and MOST important you need to actually look at the module for the revision. That is the Revision 7.4 conversation. The earlier remotes use a Revision 7.2 module but the LCD’s offered on Quin’s website will NOT work for a 7.2 module. He sometimes has 7.2 LCDs but those are used ones harvested off a bad remotes. you can ask.
Replacing the LCD requires some very good soldering skills. If you want to see how then go to Quin’s website as he has posted the repair steps for H1 LCD repair and offers a replacement REV 7.4 LCD or will replace it for you for very little.
Here are the H1 LCDs to order Quin has and the videos to watch.
https://www.harmonyremoterepair.com/stor...
I have been restoring the H1 for fun n profit for a long time as well.
Very complete directions but the entire process of opening up the remote, disassembly and repair have elements where you could turn your H1 into desk art. Be VERY careful with the touch screen cable. VERY easy to miss and ruin in one step. Quin mentions in the videos but pay extra attention to what Quin says in the Vid. Watch them a bunch of times before jumping in and then use then step by step with your actual effort.
If you do not have chip quick and good gel flux then get the LCD that comes with that extra stuff.
Tell Quin that Chuck P sent you over :)
这个答案有帮助吗?
得分 1
3条评论:
I didnt realize Soldering was needed. If your fixing these maybe I can pay you to fix mine? Search me out on FB or Twitter if possible.
完成的
@Jeremy DaCosta - happy to help. Quin can too. Realize that the LCD is about 25 dollars for the part. I would guess shipping would be 5-8 each way. The repair effort would be to disassemble, clean, R&R the LCD, put the remote back together, then put the remote through a full test. That would be $40. BTW there are a lot of Jeremy Da Costa's on FB and could not find you specifically.
完成的
Could u fix mine? I’m happy to pay. This is me on Facebook. https://www.facebook.com/alex.schmitt.56...
完成的
添加一条评论
This site specializes in them and claims to have replacements available shortly.
They have other parts and guides for them and other Harmony remotes as well. (IR transmitters etc)
I have not used them personally.
No word on pricing.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem, they suggested buying one of their newer models. This was my reply:
Thanks for your reply, but that's a very disappointing response. I'm unlikely to buy another Logitech Universal remote if support for it is so short-lived. Isn't it just a cynical way of selling new remotes by pulling the plug on older ones?
Yours in disgust,
这个答案有帮助吗?
得分 0
添加一条评论
Visit www.harmonyremoterepair.com for information on Harmony One LCD replacement parts and/or services
这个答案有帮助吗?
得分 0
添加一条评论
The Harmony One LCD's from Harmonyremoterepair.com work very well. I have used two of these. Word of caution though, and this is stated on the repair web site. The replacement LCD is only good on the version 7.4 modules, and NOT for the 7.2 version modules. Before purchase you should follow the video guidance on the repair site to dismantle the remote and check the module version. Soldering skills are also required and the LCD w/ the Chip Quick soldering aid option is required to effectively remove the old LCD without damage.
这个答案有帮助吗?
得分 0
添加一条评论
Found this https://www.harmonyremoterepair.com/stor...
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
isoS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 18,224
