跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 个问题 查看全部
How much heating I need to put on when taking apart
it is mayby little funny quastion but i need to know how much heat i need to put on the ipad 4 screen to take it apart. i mean the tempertur of the heat gun..
soory for bad english i hope you all understand and will help me out
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
You may want to get this tool kit from IFIXIT iOpener. While a hair drier will work you don't want to over heat the adhesive with a heat gun. Besides, you'll need something to wedge the display which this kit also has.
iOpener图片
产品
iOpener
$19.99
这个答案有帮助吗?
得分 1
1条评论:
70-80 ° Celcius works very fine for me. Never damaged a LCD or other part on the iPad due to heat. I'm using a heatgun from Steinel, model HL 1910 E. This model allows to set temperature in 9 different stages starting with 50° Celsius. I've put a reduction nozzle on the heatgun to direct the airflow more precisely.
完成的
添加一条评论
最有帮助的答案
All you really need is a hair dryer and a tool to remove the digitizer screen. You need to apply heat to the edge of the device until it is hot to touch. Once you have done that, you slowly begin to pry open the screen a little bit at a time. You will need to apply heat each time to continue to pry open the screen. I would suggest placing something like a guitar pick to maintain the spacing once you've begun lifting the digitizer. Better yet, order a repair kit and get the proper tools for the job.
这个答案有帮助吗?
得分 2
添加一条评论
I have tried using the iOpener on my iPad per the instructions, but I can’t get the adhesive to loosen well enough to get a pick under the edge of the glass. I have a heat gun I will use, but should I apply the heat at the face of the display glass, or on the edge where the glass and the metal meet? And what is the maximum temperature the display can be heated before damaging the display itself?
这个答案有帮助吗?
得分 0
2条评论:
Focus the heat at the edge and use a low setting. It shouldn't be so hot you can't touch it.
完成的
i set my heat gun on 130 celcius.
heat parts 5-8 cm at once.
完成的
添加一条评论
添加你的答案
Mohammed 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 431
