跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
New LCD doesn't seem to fit, also, touchscreen not responding.
My girlfriends little brother dropped his new ipod 4 touch and the screen was broken.
I bought a new screen but after following the guide and putting it back together it doesn't seem to fit. It seems to be stuck in the top-middle but after reopening it an such everything seems to be in place.
Also, when i tested the screen it did not respond to touch.
Some tips please!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Make sure you have the touch cable connected probobly and when fitting the screen you might have to bend out the corner that has been dented.. Have do this many times with pliers
这个答案有帮助吗?
得分 2
添加一条评论
This is a common error with self repairs.
What's happening is that the flex cable for the digitizer is folding the wrong way and folding over the edge of the metal shield inside. Open it up slightly and use a spudger to go in from the side and manipulate the flex cable so that it concertinas the correct way and upwards not downwards.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
sofjgiaejmaerhae 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 168
