跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Blank screen sounds working nothing else.
Last night I dropped my 4s approx 20cm , Causing the screen to go black and un responsive.
I have tried holding down home & lock buttons doesn't work , tried plugging it in and backing up.
I can use voice control and that's about it.
I can't see anything even when I reset it doesn't have the apple logo come up.
Someone help pleaseeeee !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
one of two things may have happened, you ether broke your LCD or your screen connectors came loose and need to be reconnected.
do steps 1 - 5 and skip 6 - 12. continue at step 13 and 14.
use the image to reseat the ribbons by removing them and plugging them back in.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Mairehau Rakete 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 140
