跳转到主内容
LCD becomes black at OS boot
Hello,
at power-up the LCD is white/gray with the Apple logo, then the loading logo (rotating circular segments). Then the display turns black. Everything works perfectly on an external display. I tried to change the LCD, the result is same.
What could be the problem ?
Thank you for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
thank you Dan. No it doesn't help (I used the procedure with removal of the battery).
完成的
添加一条评论
1个答案
已选择的解决方案
Did you reset the SMC? its just possible the display setting is set at the lowest brightness setting. Heres the Apple TN on how to do it Resetting the System Management Controller (SMC)
这个答案有帮助吗?
得分 1
12条评论:
OK - Try this, after booting using the keyboard brightness buttons lower the brightness to the lowest setting. Then slowly raise it does it light up? Also if you use a flashlight though Apple logo can you see your desktop image?
完成的
No, both operations don't show anything.
By the way, here are the graphics properties (with the external monitor L72D connected):
GeForce 8600M GT:
Chipset Model: GeForce 8600M GT
Type: Display
Bus: PCIe
PCIe Lane Width: x8
VRAM (Total): 128 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0407
Revision ID: 0x00a1
ROM Revision: 3175
Displays:
Display Connector:
Status: No Display Connected
L72D DVI:
Resolution: 1280 x 1024
Depth: 32-Bit Color
Core Image: Hardware Accelerated
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Rotation: Supported
Thanks
完成的
If you don't see a ghost image of your desktop with the flashlight your LVDS cable or the display is bad. As you replaced the display (hopefully with the correct one) then the cable is likely bad.
完成的
That was also my reasoning: I checked the LVDS cable wire-by-wire, and its seemed OK. What puzzled me in the graphics properties is: "Display Connector: Status: No Display Connected", as if the LCD doesn't enumerate.
It is a correct one, it behaves exactly as the original.
完成的
Did you put the LVDS cable in upside down? If you did, you might have blown the fuse links (near the connector) marked with a letter 'P.
完成的
显示更多的7条评论
添加一条评论
添加你的答案
TTR78 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 177
