跳转到主内容
加入维修社区 - 创建账户
Apple 專為可望極致效能專業使用者所打造的產品線。目前, MacBook Pro 產品線包括 13、14、15、16、17 英寸機型,並且大致分為原始非一體成型機身、一體成型機身、視網膜螢幕、觸控列、Apple晶片五個世代。
How to Reset Password?
How do you reset the password? note: i forgot what the password was even after the hint: " ".
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
1条评论
How to recover online?
完成的
添加一条评论
2个答案
已选择的解决方案
Here are the instructions from Apple on resetting your password. Ralph
http://docs.info.apple.com/article.html?...
这个答案有帮助吗?
得分 6
添加一条评论
Turn off the computer. After it is completely shut down hit the power button while holding "command s" Once all the text has loaded tip the following without the "" marks and with the spaces in mind. Also enter is just hitting enter and not typing enter.
1. "sbin/fsck -y" then hit enter
2. "sbin/mount -wu /" then hit enter
3. "cd /var/db/" then hit enter
4. "ls" then hit enter (notice this is a lowercase L)
5. "rm. ./.AppleSetupDone" then hit enter
6. "ls" then hit enter (again a lowercase L)
7. "reboot" then hit enter and wait.
When your mac starts up the next time it will be tricked into thanking its new and make you go through the info process. This will create another admin account. When you log into the account that you have just created you can go to system preferences -> accounts -> then select the account that you forgot the password to and hit change password. Then log into the previous account and delete that account that you just created and walla!!! You now have a password that works.
这个答案有帮助吗?
得分 4
1条评论:
there needs to be a "/" before the sbin in the first two steps
step two, its "-uw"
完成的
添加一条评论
添加你的答案
Bhoutik Mehta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 26,604
