跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
which power/volume control cable do I need?
Is the CDMA version of the power/volume control cable the right replacement? beacuse the one for the old ipad 2 model is to long, the only one that looks the same is the coma version, should it work here? thank you :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
New iPad 2 wifi use a special cable, for this device only. Cables from other models are not compatible
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 276
